Changing app's locations on the android main screen
    Hi All.
    I'm working with : M8S Android TV Box S812 2/8.
    My question is what is the way to move the kodi app location in the main screen.
    Just to clarify,
    My friend has the "k1 android tv box", when the screen of the Android opened,
    The kodi app icon is located in one of the four large squares. When my is located down in the screen. Next to the icon of the Android store.
    I tried to find a method to drag him up without success.
    Thanks,
    Rafi.
    That's hardwired in the home screen app, there is no way to move it. What you could do is copy the app from the K1 rom, and install it on your M8S. It's most likely called media box.apk or similar in the system apps folder.
