A new version has been released for Android
If for some reason the OTA update fails, you can manually download the update files and follow this guide to do a manual update:
Download WeTek OS 1.1.6
[/FONT][/COLOR]
Use Wipe data and Wipe media IF you want to make a clean installation
(This will delete all the settings on your WeTek)
Or
If you want to make a clean install or recover android on NAND
[/FONT][/COLOR]
After this new installation finishes, please turn off your WeTek.
After turning on, please make a reboot, for the apps ti update properly
Thanks!
Best regards
We are proud to announce that we start seeding OTA update of WeTek OS 1.1.6
Code:
[COLOR=#333333][FONT=source_sans_proregular]https://mega.nz/#!jABx1ZoR!Joen3APJiu4JetTmYS_tfJVeJJVt-2e3UPolWSpDRno
Or
Code:
[COLOR=#333333][FONT=source_sans_proregular]https://mega.nz/#!uVBXwJzB!SGvb9hsxYBdOXpRCi4dAPw0CgmAXrtgDjWrmyvxp blQ
Code:
[COLOR=#252C2F][FONT=Helvetica][SIZE=13px]Changelog of the new 1.1.6 version[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]Android:[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Fix bug with delete button:[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Use long press button "delete" to take a screenshot[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Add Hungarian language[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]WeUpdate:[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Improvements on Turkish translation[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]WeTek Theater:[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Fix DVB-T 7M Bandwidth issue[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Changes for LNB power off on exit(s)[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Switch off LNB before standby[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Update SAT and SRV table after merge[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Fixed crash ATSC tunner when start theater[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Mask ATSC subtitle[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Add Russian and Ukrainian translation[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Fix DVTplayer crashing (back to launcher black & need double exit)[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Disable MultipleFrequency function[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Improvements for Australian users[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]Launcher:[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Add TalkBack in Launcher's Main screen[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]Update Apps:[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- New KODI 15.2[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- GAPPS[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Aptoide[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- others apps[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]On a Clean installation:[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- YouTube for Google TV (discontinued version) Deleted[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Skype Deleted[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Box Deleted[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- Chrome Deleted[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px]- ES File Explorer Deleted[/SIZE][/FONT][/COLOR] [COLOR=#252C2F][FONT=Helvetica][SIZE=13px][/SIZE][/FONT][/COLOR]
Thanks!
Best regards
