So after, what I thought was some reasonable research here and elsewhere I decided to get an MXIII Plus from Geekbuying...all good so far. It arrived with 106L1 FW and Kodi 15.2 and after plugging it all in seemed to work except for a slightly shaky display which I've since traced to the use of the active U-Vision upconversion cable I was using successfully on the Meta with my 4K TV. No shaky display with a normal HDMI cable.
The other thing I noticed was that whenever I enabled the AMlogic hardware acceleration codec in Kodi 15.2 the box would freeze when I started to play a video....the only way out was to pull the power plug and reboot. So further research on the Kodi forums shows that since Isengard the Kodi devs have removed some sort of internal acceleration workaround requiring a rooted box and Kodi compliant firmware.
That was what I thought I was buying....So there was some discussion about SPMC working correctly (I was using SPMC on the meta so am familiar with it) so I loaded up the latest SPMC (fork of Isengard 15.0) but it still won't allow the Amlogic codec to be enabled...box still freezes. Now I left Kodi 15.2 on the box as well, should I have completely uninstalled that before installing SPMC or should I wait for yet another Trony fw to be released or should I learn how to use init.d and the Chmod 666 command scripts...as I say I'm still an droid newb so mucking around with system files scares me a bit.
No one here has bothered to respond to my other posts but if someone could point me in the right direction....or do I just try to get hold of another RK3288 box and give up on Amlogic socs...if that is the right terminology...or in fact is there a better firmware that allows the Amlogic hardware acceleration to be enabled...I am probably willing to go back to a droid 4.4 fw with SPMC 14.2 except I guess there will be some add ons that depend on Isengard now...
Any help....?
