Specs are...
CPU : ARM Quad Cortex-A9r4 upto 2GHz (DVFS)
GPU : Octo MaLi-450 up to 600 MHz+
Flash Memory (NAND) : 8 GB
DRAM : 1GB
WIFI 2.4GHz 802.11 b/g/n
OS : Android 4.4.2 upgradable to AndroidTV
USB 2.0 : 2
OTG (Mini USB) : 1
Micro SD (TF card)
AV : Yes
LAN Ethernet (RJ45)
Micro SD (TF card)
SP DIF (Digital Audio)
IR Interface
I want to flash a stock FW, anyone any ideas what it is or what I can put on it?
