M8 Freezes. No matter what ROM is installed
After a long time on CodeSnakes OpenELEC ROM with very few issues, my M8 box started having problems. I have now tried many of the popular ROMs on this forum to no avail. My M8 box consistantly freezes. Is it possible that this is a hardware issue they cannot be solved by different software?Tags: None
What kind of freezes? Just stops working? Has freezes from time to time then resumes?120" screen, EPSON 6100W, YAMAHA RX-V775, B&W 603 (front), B&W CC3 (center), B&W DS3 (surround), Boston Acoustics SoundWare XS (front heights), SVS SB-2000 (subwoofer)
M8 TV Box Codesnake's OpenElec 6.0.3
Tronsmart MXIII+ (v108L1) + KODI 16.1 (Jarvis)
Originally posted by neomode View PostSounds weird, but exchange the Battery on Remonte.
This Will Help for sure.. Low quality batteries die slowly and may accept some keystrokes but then voltage gets too low to operate the remote properly.
High quality ones do live longer, but die abruptly.
My M8 (square unit from OTT, 2GB ROM, old round remote) freezes too. Nothing related to the remote, though, because I am using a USB mouse (with cord, not wireless). Like Tyler Durden, I have also used Codesnake's (or Kerber's) Openelec for over one year, but now I use Megatron's Android v3.
With any of those ROMs, while watching movies under Kodi the video can freeze unpredictably, the audio mutes and the system becomes unresponsive to both remote and mouse. It does not matter whether the file is local (USB disk) or networked (my NAS server). The only remedy consists in disconnecting the power supply. Hopefully, upon reconnection, the system keeps track of the point at which it was forced to stop, and the movie can be immediately resumed from that point.
Watching movies from Android without using Kodi (i.e., under Acestream) results in the very same problems. Perhaps it is a hardware problem, as suggested by Tyles Durden?
Anyone else experiencing these problems?
It may not be ROM related. I have a Pipo X7S and I too have this issue. It is running Windows 10 and the problem is not predictable at all. I activated the Easy Advanced Settings program and upped the Buffers and other network related things that I could tweak, with no change. This problem does not seem to be network related. The videos on NAS devices on a gigabit backbone, so is the Pipo. Running Kodi 15.2.
I recently moved my M8N onto an AC Bridge, in another room. This is running JustMe's 1.9 ROM and it seems not to have this problem. I will concentrate some more testing on this setup.
I have been searching the various Forums concerning the problem and this is the first one that hits my problem exactly. Let's hope some can help us.
Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
Originally posted by clarkss12 View PostTry another power supply
Many issues on a variety of boxes have been traced to irregular power supplies. "Dirty" power supplies can mess with digital devices in a variety of ways.
Good luck to all.
I went back to Kodi 14.2 and reconfigured my network settings - can't explain why but my network submask was changed from my original configuration.
No more freezes (remember, my freezes were temporary not permanent).120" screen, EPSON 6100W, YAMAHA RX-V775, B&W 603 (front), B&W CC3 (center), B&W DS3 (surround), Boston Acoustics SoundWare XS (front heights), SVS SB-2000 (subwoofer)
Thank you, clarkss12!
It was indeed a problem from the power supply, but not due to the PS itself.
When the PS was plugged on a multiple socket extension the M8 unit showed the unstable behavior described. Upon changing to a wall electrical socket the problem disappeared altogether. Since then it has been running under Kodi 15.2 for over two and a half hours without any issue. Perhaps the unstable behavior was caused by the plugging of too many appliances.
Incidentally, I found similar instabilities in the quality of a Power Line Connection (PLC) Ethernet signal delivered from another multiple socket extension. Again, the unstable behavior disappeared when the PLC unit was plugged to a wall socket.
There are currently 6265 users online. 3 members and 6262 guests.
