, I have just bough beelink i68
the primary disk from 8 gb is divided into two partitions. the first has 1.60 gb available and the second has 3.10 available. So I put a sd card in external SD slot. Now, when I install the app, they are always installed on the first partition (the residue from 1.60 gb) !! Even if you use the “move to sd” ..the only thing I can do is move some (not all) of the space occupied by the app on the secondary partition. How do I use the external SD ??? for me it is impossible to use the external sd to install games or apps
How can i fix?? I want to use external SD space to install games!
here's my model:
