MK808-Can I install Android 4.1.1 and Finless 1.7C if I have V4.2.2 an d Finless 2.1 now?
    Hi Guys,
    Just like to know if it is possible to flash to v4.1.1 and finless 1.7c if i have v4.2.2 and Finless 2.1 in my mk808 now?
    Bob's readme first.txt mentioned something about a huge system.img. I was wondering if this will cause problem or prevent downgrading to v4.1.1 and finless 1.7c?
    Feedback and pointers are welcome and appreciated. Thanks
    Originally posted by atac5922 View Post
    Hi Guys,
    You can flash any ROM you like - the old one will be wiped out so it's not a problem. Will be a fresh install, not like upgrading or downgrading. Just make sure you save any data you want to keep before you do.
      Ok. thks.
