My Look at the Beelink R68 TV Box RK3368 Android 5.1 (2GB+16GB) SIlver:
    Here we have another, A Beelink RK3368 Metal Box 10/100/1000 Lan, AC WIFI
    A few photos to start of the Beelink RK3368 and hoping for something real different here.
    The over all build from the outside I feel is how all boxes could be with a bit of a price.
    Solid Metal Box, External antenna, frosty silver finish. Looking good.
    Plenty of Ports to plug into and my biggest shock it has been supplied with an AU power adapter. Excellent.
    Lets pop a few pictures.
    The facts as Advertised and written
    ● With powerful RK3368 64bits Octa core Cortex A53 CPU, gives you a better performance and better power efficiency at the same time.
    ● The latest Android 5.1 System. Support GooglePlay and many Android market which are more convenient for you to download all the APP free.
    ● With all new metal shell material design, the new appearance is more concise and more abundant.
    ● KODI pre-installed: Over 50 most popular Add-ons installed in your KODI.
    ● 4K x 2K H.265 / H.264 decoding and playing ultra HD video, brings you excellent definition even on a larger screen. The 4K x 2K UHD video playback feature means smoother edges and depth, enjoying a superior viewing experience.
    ● Built-in dual band WiFi (2.4GHz + 5.8GHz) simply connect to any network wirelessly with any security type and stream your favorite content without the hassles of wires.
    ● 2GB RAM + 16GB ROM, 64GB maximum extended capacity gives you more space to download your favorite apps and caches to browse websites, play games, run apps, watch movies more smoothly.
    ● HDMI 2.0 connector: You can go directly to let your TV and Beelink R68 are connected through a HDMI cable and set up your home cinema for the best 4K x 2K HD multimedia experience.
    ● Built with Bluetooth 4.0 available for connecting Bluetooth speakers, keyboard, mouse etc.
    ● Infrared remote control let you enjoy your wonderful life which the wireless brings to you.
    ● USB host ports: Connect with your mouse and keyboard to help you operate more convenient.
    ● Support 10/100/1000 LAN.
    Some more pictures bit of a different look.
    More Facts/Specifications on the Beenlink R68
    Brand: Beelink
    Type: TV Box
    Model: R68
    Color: Black, Silver
    System: Android 5.1
    CPU: RK3368
    Core: Octa Core
    RAM: 2G
    ROM: 16G
    Max. Extended Capacity: 64G
    Media Supported
    Decoder Format: H.264, H.265
    Video Format: 4K x 2K, RM, ISO, MP4, AVI, DAT, WMV, MPG, MKV, MPEG, MOV
    Audio Format: OGG, MP3, WMA, AAC, FLAC
    Photo Format: JPEG, BMP, GIF, PNG, JPG
    Specification
    Support XBMC: Yes
    WiFi: 802.11 a/b/g/n/ac
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: USB2.0, LAN, SPDIF, Micro USB, Micro SD Card Slot, HDMI
    Certificate: CE, RoHS
    Package Contents: 1 x Beelink R68 TV Box, 1 x Power Adapter, 1 x HDMI Cable, 1 x Remote Controller, 1 x English Manual
    Ok now inside we go for a bit of a look see:
    Well I didn't expect that, (that is different) someone got it wrong in the sticker factory.
    Even tho its pretty much common knowledge.
    More to Come..
    Cheers
    Some Antutu V6 numbers to look at.
      I have the same
      If it were not stuttering , it would be a great player.
        Yet to get that far as yet..all in good time, just loading it up and run some tests, soon.
        What firmware are you using, this has V1 dated August I recall
        Cheers
          Cheers
          I tested all of them, nothing helps
          I am waiting for good rom's from Wasser or Tronsmart
            Very nice metal box Hope they come out with a 206L firmware to fix the stuttering issue. Since the new 205L firmware did not solve the issue on Tronsmart R68 which uses the same hardware as the Beelink R68.
              I am curios if they had a few boxes live (Zappp) before they realised they needed the insulating pads to stop the Base Connecting with lower PCB (Zapppp)
              Cheers
                Can you advise a sample video that stutters with the Beelink R68g and what settings noted in Kodi,
                Not a big user of Kodi so lets know the deal.
                Cheers
                  Good to see some people getting them.
                  Beelink promised a number of them for reviewers and then went silent.
                  Had to laugh at the Tronsmart sticker.
