I have a few (probably dumb
1) Does Bluetooth use the antenna too, or is it just for wifi?
2) How does the antenna work? I mean, if I were to just solder the antenna wires to something big and metal, would this improve signal strength, or is there more to it?
3) Do the two antenna wires need to be connected to two separate (i.e. not touching) parts of the antenna, in order for it to work?
Thanks in advance.
