Attention! At ARNOVA 8G2 4Gb or resistve touch is not works!
Differences firmware.
- Support for Ad-hoc
- You can choose the size of userdata - 1, 2, 3 Gb
- Sections converted into a format the ext4 file system
which is much faster read/write data,
allows to edit, add and delete files in it.
- Set aside for user data 1Gb memory. This will allow
install more applications.
With the increasing number of applications increases the start time.
- Updated some applications.
Thanks fenice57
- Added support for modules BT, *
3g USB-modem Hauwei models E1550 E1692 E1750 E1820 *
Thanks Morka
- Interface HoneyComb (Android 3.0)
* Requires verification and debugging.
Manual and drivers in the archive
ROM -> AN8G2-v5.02 ROM by Sowa (141Mb)
