New user beelink i68, How to shut down the device ?
Originally posted by imperatores View PostHi, i cannot shut down the device. When i press the red button on remote control ,the device goes to sleep. Can you help me? Thank you
In google play store install the reboot app ( the purple one ), works great, it will do reboot and also shut down the box. Load boot loader, recovery and other functions not working or needed on the i68.
https://play.google.com/store/apps/d...s.tools.reboot
Thank you so much! Is there any way to connect the remote control with this app? (Example: when i press the red button on remote control, The app Reboot will open)
Firmware 201L had the Long Press "Shutdown" option .... Firmware 204L removed it and replaced it with "Reboot" ... which personally, i think was f***ing stupid decision
http://freaktab.com/forum/tv-player-...h-october-2015
i68 TV BOX ,Download the latest firmware
current version:update_I68G_204L1202
Based version:update_I68G_201L1200
Update:
1.Preloaded "RK" a customized version kodi 15.2.
a.Hardware acceleration:Support H.264 4K @ 25fps, H.265 4K @ 60fps and other mainstream video formats mpeg4 the hardware acceleration.
b.HDMI transparent transmission:Support ac3 Dolby Digital, eac3 Dolby Digital Plus, DTS, DTS HD, TrueHD other audio format.Maximum support 7.1-channel Source Code unvarnished transmission
c.SPDIF optical fiber source output(transparent transmission),Support ac3 Dobly Digtal, DTS,Maximum support to 5.1 channels.
d.Supports HD 3D video output.The default output for Left/right 3D format , Playback setup can switch to 2D format , Up / Down 3D format and so on.
2.Ethernet MAC address:Wifi MAC address in above plus 1
3.Support YouTube 1080p video playback
4.Removed power off functionLast edited by JoeySmyth; 04 December 2015, 10:39. Reason: Because Firmware Feature "4" was decided by a F'ing Idiot
There are currently 2777 users online. 1 members and 2776 guests.
