Is there a way to keep my drive letters permanent on my MXV? Most of my video playback is through a HDD or USB flash drive. Depending on what i plugged in first/last, the box assigns a drive letter that sometimes breaks my kodi library.(Hard drive reads as sda1, USB flash drive sdb1)
So if i unplug my HDD to add a few shows from my PC, and then plug it back in, in the wrong order, it'll mount the drive as sdb1(thereby breaking my library, as all the files were sourced when it was sda1)
Is there a way to tell my box that ONLY my HDD can be read as a sda1 drive?
