USB OTG not working
USB OTG not working
On my Z4 I have flashed latest firmware 12/21/2015 but its OTG is not working no devices can be detected if I use OTG cable. Same cable works on other android mobile. Does someone face similar issues. Also USB host port issue I am facing my portable HDD many times are not detected on both USB host ports.Tags: None
Originally posted by vinaysharma76 View PostOn my Z4 I have flashed latest firmware 12/21/2015 but its OTG is not working no devices can be detected if I use OTG cable. Same cable works on other android mobile. Does someone face similar issues. Also USB host port issue I am facing my portable HDD many times are not detected on both USB host ports.
Also can you flash firmware from the future?
I flashed rk3368_5.1_Z4_ap6335_zhongxing_20151121.zip from http://4pda.ru/forum/index.php?s=&sh...ost&p=44789506 . If this is not the latest ROm for Z4 what can you help where can I find the latest ROM for Z4. Factory ROM also had power shortage issues for my portable external HDDs in both Host USB ports. I am using Buffalo MiniStation 1TB Portable hdd in my case.
Everything else except OTG and host USB poer for HDD works very well. Camera / game controller works fine with USB.
Finally I figured out the problem. It was the setting under USB settings . if you select connect to computer check box. USB OTG can not detect any other device. if you un check it will work properly. But Still canot figur out how to get enough power for 2.5 inch USB portable HDD when connecting to USB host ports or OTG. these are not getting detected intermittently. Also can not make USB camera mic working so far.
There are currently 3610 users online. 1 members and 3609 guests.
