I really need help from experts! I got my Pipo m6 pro yesterday and almost everthing was fine. I could turn on wifi and connect to the internet. But stock rom was a bit laggy so i decided to flash riley rom 1.6. I thought everything was okay, did it like in instruction said and i got no error messages or such things while flashing. Then i waited until the tablet booted up and everything was just fine, expect wifi and bluetooth. I was not able to turn it on. It was saying "turning wifi on..." but nothing happened. Sometimes the button moved to the right but shortly after back to the left. I tried hard resets, wiping and even different custom roms and in the end stock rom from pipo server. Same result. Im just not able to turn wifi or bt on. I read about that problem as a generell problem on android sometimes. But nothing helped yet. I dont know what to do. Unfortenately the tablet was uses so i dont know which rom was installed when i got it. It was some kind of stock i guess, because of Pipo launcher and chinese language. But in comparison with the stock rom running now i couldnt chose between diplay modes for instance... So if anyone can help me i would be thankful!!! Oh i forgot: i flashed the costum roms with Rom_Flash_Tool_137 and stock rom with RKBatchTool unsing restore button.
Need help with wifi and bluetooth on Pipo m6 pro
Hello,
I really need help from experts! I got my Pipo m6 pro yesterday and almost everthing was fine. I could turn on wifi and connect to the internet. But stock rom was a bit laggy so i decided to flash riley rom 1.6. I thought everything was okay, did it like in instruction said and i got no error messages or such things while flashing. Then i waited until the tablet booted up and everything was just fine, expect wifi and bluetooth. I was not able to turn it on. It was saying "turning wifi on..." but nothing happened. Sometimes the button moved to the right but shortly after back to the left. I tried hard resets, wiping and even different custom roms and in the end stock rom from pipo server. Same result. Im just not able to turn wifi or bt on. I read about that problem as a generell problem on android sometimes. But nothing helped yet. I dont know what to do. Unfortenately the tablet was uses so i dont know which rom was installed when i got it. It was some kind of stock i guess, because of Pipo launcher and chinese language. But in comparison with the stock rom running now i couldnt chose between diplay modes for instance... So if anyone can help me i would be thankful!!! Oh i forgot: i flashed the costum roms with Rom_Flash_Tool_137 and stock rom with RKBatchTool unsing restore button.Tags: None
There are two things you might check.
Have you flashed back to the stock ROM? Is wifi and bluetooth still not working?
The M6 Pro is a very good device, but came with some production quality flaws. The antennas for wifi and bluetooth had some soldering defects. There is actually a whole thread in the main Pipo section (sticky) that takes you through the process of fixing the antenna connection. You might have received a tablet from that production run.
Why the problem became an issue after you flashed my ROM is a mystery to me. You might try flashing an older firmware version with an earlier kernel to see if there was a driver change that adversely affected your tablet.
Randy
There are currently 1162 users online. 1 members and 1161 guests.
