HPH NT-V8 RK3368 Stock Firmware - 3 Dec 2015
    Hi
    Here is the latest stock firmware for HPH NT-V8 RK3368
    from 3 December 2015.
    Link
    Decryption key: !IYT6TN9AOf4Qh8sWs1_XYVIJC7jDGLvBYXIBWuXov7Y
    I must say it is really stable.
    Includes LeHome Assistant from RK3288 that allows you to control the tv box from your phone or tablet by means of
    airmouse control
    touch control
    screencast
    it's one of the best Android remote control apps out there, only compatible with HPH NT-V8 tv box so far.
    UI is also more snappier
    Launcher has a new Kodi section instead of XBMC
    Easy Root/Unroot access - Go to Accessibility Options
    Rockchip Kodi(Please tell me if there are still any problems with Rockchip Kodi eg. streaming addons, black screen etc.)
    I will make a custom ROM tomorrow with some extra features and updated Kodi.
    Many thanks for the link..
    I look forward to testing your enhanced version!
      can we get 4k 10 bit playback with this mo ?
        I don't think it's possible since the GPU doesn't support 10-bit x265 according to a lot a threads, the information on Rockchip's website is incorrect.
        You should be able to play 720p 10-bit x265 with software codec in BSPlayer.
        When new Lollipop firmware is released for RK3288 it will be able to do 10-bit x265(can already do it on KitKat), but I don't think on RK3368 it's possible that's why it's cheaper.
