My first post here
Originally posted by 3db View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by 3db View PostIs it a hardware limitation or an Android limitation?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
That is a good question, I believe it is a firmware limitation. A few manufactures, like Wetek and Zido are able to squeeze HD audio from the Amlogic S812, like yours, but most manufactures don't, including Minix. Of course Minix uses a special version of Kodi that you pay $15 a year for the ability to passthrough HD audio.
From my understanding, your stating that it won't stream HD with the Kodi application. Will it stream HD material from a USB drive?
It is my understanding the new Wetek Core will passthrough HD audio, and it is using the Amlogic S812.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
WeTek Core is using the AMLogic S812-H which has hardware HD audio decoding. It also has Dolby Digital Plus (5.1) and DTS-HD (M6) decoder licenses. Google Certified device (Widevine level 1,2,3) = 1080p HD Netflix and other copy protected video streaming Apps at 1080p HD. It does not play BluRay ISO Rips with HD Audio though. More info on Kodi forum http://forum.kodi.tv/showthread.php?tid=238923Archos Gen9 A80S cm-11.0
Kindle Fire 2 cm-11.0
No HD audio at all. None of my Android boxes will passthrough HD audio.
There are currently 2142 users online. 1 members and 2141 guests.
