Need help box won't flash any firmwares
    So I just got my m8 from gearbest, the board version shows m8 & m9 v2. There is no recovery on it so a recovery.img needs to be places with the firmware on the SD card. Anytime I try to update the firmware it always gets stuck the animations stop even after 15 minutes the progress bar doesn't even move. When I tried to install openlec itwent further but now the box won't even load into the OS. But I can still get in to try and load firmware. The same way as before. Any ideas? I've tried every custom roms and all official rom on GeekBuying.
    Originally posted by eboxsupport
    Hi CBQFLY, we have some firmware on our site that you may try on your eny m8. Please click here : https://www.entertainmentbox.com/dro...ware-download/
    thanks i did try that one and it failed, i then went to flash an s812 firmware on and the staus bar did not freeze and completed but then ended up bricking my bock because i only had the blue light then proceeded to use the recovery from the s812 rom to flash finless and then i got pure red light. now i am stuck trying to find the correct img file to flash using usb burning tool. getting stuck at 2% probably because it's not the right image.
      looks like it's a paper weight now. usb burning tool is not even detecting the box at all now after a few different flashes
