No custom rom for momo11 speed?
    I know this tablet is getting "old" (couple of month, but its still a good RK3066 tablet), but I cant find any finless rom for this.. someone got an alternative?
    I have the on with the gray back. (no black strip... no serial number ;( )
    a v1 or oem?
    3.0.8 root#32 SMP PREEMPT Mon Sep 11:30:57 CST 2012
    build
    xzh970_1.1
    v1.0-eng 4.1.1 JRO03H eng.root.20120818.154714 test-keys
    I found this rom "Ployer Momo 11 Speed Version-3 TNT Release 1 Firmware"
    -Rooted
    -Based on stock rom (2012.12.07)
    -App partition is Larger
    -Build.prop mod based on SGS II SGH-i777 for improved market
    -Added Permission Files for improved market
    -Removed Chinese Apps
    -framework.jar mod for better gameloft compatibility (Asphalt 7 should now work)
    -Added SuperSu, gallery with picasa support, ESfile Explorer, english dictionary fix
    -Simplified and pretty boot animation
    -Changed Annoying Keyboard Key-press sounds... now they are less annoying (based off Cyanogen sounds)
    -Default Background should be changed
    -Changed "browser" start page to our Google paid search. Use it (free to use for you) to search the web and you will be helping to support us as we release more free firmware. Can easily change this if you want.
    it's working fine!
    its based on a old firmware (december I think), ployer released a new firmware on march.. (found the link on comment, you need to go to the chinese site, english web site is empty)
      Have a look at this guys site flexion.org, he has done a good job on improving the rom for momo8 ips rk3066, it may be compatible with your's.
        thanks, I will check if its work on the momo ployer 11 tablet!
