Having a problem downloading some apps
    I have an MK808 running 1.7C. There are a few apps I have purchased from the playstore that say they are not compatible with this device. How can I resolve this?
    livinLife
    Found this May help ?
    Found this info in Instagram FAQ's
    "Device not compatible" error message in Google Play Store.
    We are aware of an issue where some users receive a "Device not compatible" error message in the Google Play Store when trying to download Instagram, even though Instagram should support the device. Google is currently investigating this issue with the Google Play Store.
    As a temporary workaround, Google suggests clearing the Play Store's data from your device and then attempting to install Instagram. To do this, go to Settings > Apps > All > Google Play Store > Clear data.
      The easy way? Use the Hybrid rom.
      Currently Using:
      2 x Nvidia Shield TV | MiniMX III
      Retired Devices:
      MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
        I have already tried clearing data on the playstore and download manager. The game is modern combat 4. What hybrid rom are you talking about? I really like the rom I am using.
