M8N, Bricked or Dead?
I have no clue if my Android TV Box M8N is either dead or bricked. When I plug in the power it will flash the blue front light and flicker off. Same thing with trying to connect through a USB from computer. This occurred while trying to flash to back to an Acemax firmware after the EntertainmentBox firmware would boot. So all the sudden the blue light no longer was on so I'm not sure if I shorted the board trying to plug the loose cord back in. Try the Unbricked method using Windows 10 but can't seem to detect it with the USB Burning Tool. So just wondering if it is "Bricked" does the blue light in the front stay on or off? Thanks.Tags: None
There are currently 6347 users online. 1 members and 6346 guests.
