Decryption password for MK918
if you google the issue, you see its a common problem
try
Press and hold Reset button.. Power device to boot into Recovery mode. You will see an image of an Android robot with a red exclamation mark. (release button)
Use the keyb to scroll to "wipe data/factory reset" and press Enter to select it.
Scroll down to "Yes - erase all user data" and press Enter to select it.
goodluck
ps..all your data and apps will be lost! using the above solution
There are currently 2451 users online. 1 members and 2450 guests.
