Anyone with a new MK808b Plus and an rtl8188eu usb wifi adapter willing to help
Anyone with a new MK808b Plus and an rtl8188eu usb wifi adapter willing to help. I want to try to come see if wifi will work if using ko module from inphic rom. If so let me know. Trying to make a solution for those with poor wifi and use an external usb adapter.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****Tags: None
OK I got one. But need some help still. If I flash inphic rom WiFi works with usb WiFi adapter but would like to get the necessary files to make work with stock 109. I moved all the files that I think should. I get 2 wlan adapters after insmodding 8188eu.ko. i have no idea why 2.any advice is appreciated. I'll keep testing hopefully I'll find the right combination. Do you think I should move wpa_supplicant from inphic...I'll try without next. I did a lot of comparing with beyond compare. And it was one of the ones WiFi related that was differentPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Just an update. I got it connected to WiFi now. I can get an ip address and see it connected to my ap but is still running over internal WiFi. I think I just have to get my routes corrected to go over wlan1. Had to get some sleep will continue tonightPrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
i got it working and it is such a simple hack. I hope it works on all s805 devices. I will post directions tonight. Freakn uncompressed mpeg2 from my hdhomerun works from 40 feet away.Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
There are currently 2166 users online. 1 members and 2165 guests.
