I have received my Beelink i68 from Banggood. On the site, the description says that it's a 100 mbps Lan, but on my router the gigabyte orange led is on ( green and orange)
If I check the ethernet tvbox with app "Wifi speed test" which enable to test lan network I can't get any speed measurement but it app says : link speed: ethernet mode 100 mbps (estimated)
Then, the model number is i68G. I guess G means Gigabyte.
So, how to know if it's the 100 mbps or 1000 mbps device?
