A BIG thanks to aganno for testing the ROM. This is based off the same MXIII 115k4 firmware, but has a compatible bootloader installed that allows for going in and out of shutdown and standby using the original remote
Just like the other ROM, there are some tweaks to improve network performance, and no apps are included, it will simply upgrade the ones you have installed.
**Bluetooth doesn't work on this ROM. I'm busy trying to fix it, and if successful, v2 will have it
**widevine is enabled on this ROM, and correct kodi permissions are set in the boot image (thanks vn800art)
New Custom Bootlogo
**This firmware is for the Eny M8 S802 Quadcore Media Player
HowTo Install: Extract contents of the .zip to a Fat32 formatted SD card and reboot into recovery. See here for details
Feedback is greatly appreciated
**Download at your own risk**
By Mediaman
