Do USB webcams work with the CX-919?
    Does anyone know if USB web cams work on the cx-919?
    Want to thank me for my work? Donate to one of the administrators of this forum here or here, thanks!
    on the Android 4.1 stock rom,it has a bug when you the usb camera, but after update to android 4.2, you can use the usb camera without problem.
    the android 4.2 stock rom will come in this week.
    stay tuned.
    Looking for developers
      Will the new firmware solve the problems with XBMC as well? XBMC keeps crashing on my CX-919
        check which version do you use, i try this version
          http://mirrors.xbmc.org/nightlies/an...rmeabi-v7a.apk
          That's the one I was using. It installs fine but crashes often. I'm now using the latest nightly. Works better so far
          Just wondering, how come the official XBMC releases don't work with the CX-919?
            First time poster here. I have cx-919 from Geekbuying flashed it with 4.2.2 by Finless (thanks mate) but can't make my usb cam to work. It is a cnr-wcam820 (not the hd) but is supposed to be driverless and worked fine under linux. Any help with getting it working is appreciated. Btw should i plug it in the OTG port or the normal usb should work (don't have a micro usb to female usb cable right now)
              ups allowed ?
