I just bought an MXIII-G, I have a problem: when using the store's "search" feature, it crashes when typing "ple". Everything works when I type "pl", but crashes when I enter the following "e". It does not crash with other character combos, such as "lau".
Updated to firmware 106L1, but nothing changed. Any idea of what can be the problem?
Also, how do I reboot/shutdown the device? The launcher is missing any button for power.
Thanks!
