backedup deleted system apps how to restore it ?
need your help a virus similer to monkey test i almost solved the problem with titanium backup app until i deleted too many system apps now my tablet stuck on android logo however i backed up all apps with titanium and copied it to my computer .. please tell me there is hope i almost solve three month problem by following steps with titanium but i over done it i hope there is still a solution with the back up i made.i rely don't care about the data my problem always was that i never found a rom for my device but i am no expert it could be there and i did't not see it, the virus was similar to the monkey test but it wasn't the same that's why it was hard to follow steps latterly, what ever it takes to get my device back it so important for me, i will right the build number for the tab and uplode all apps images and a video for it"s settings ,model number and virus apps,only images was after deleting obvious virus apps. rely appreciate any help.build number: rk_30 android 4.1.1 sdk v1.00.00 bsmart bs101 v1.0 20130316
need your help a virus similer to monkey test i almost solved the problem with titanium backup app until i deleted too many system apps now my tablet stuck o...Tags: None
I looked it up and saw that someone flashed it with u30gt firmware, and it boots except wifi doesn't work. You might try to find a tablet rom for rk3066 device and flash until you find one that works altogether.
It's probably a rebranded cube or similar.Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
i spent the past time trying to learn more about adb ,and i found this video when searching it could be the solution for my problem and i hope it is helpful video for others. i don't want to make the same mistake twice so i'm waiting for your advice before continue in these steps, also i put an image after i did the first step only to make my computer reed my tab on adb
Stuck in a bootloop? ROM files corrupt? This tutorial will show you how to transfer files to your phone using ADB. As long as you can boot into recovery, you...
There are currently 2232 users online. 1 members and 2231 guests.
