CX-998C, what roms are compatibles ?
same order item, do not try http://blog.geekbuying.com/index.php...ased-20141121/ as it's made my unit bricked.
I don't believe it's possible to brick a Rockchip device if you flash Rockchip firmware. Try the Neomode Source ROM and RKM V5 Lollipop Beta on it if the stock ROM is available. It probably will work.
That is, as long as you aren't messing with the bootloader.Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
CX998C work well with RKM v5 lollipop beta.
Neomode Source Rom - Android 5.1.1 - MK902II and RKM V5
Still question to me this stock does not work. After flash this it reboot and dead. http://blog.geekbuying.com/index.php...ased-20141121/
Ir remote control never work.
Hello I Just flashed http://freaktab.com/forum/tv-player-...t-for-htc-3288 and al that is good works I have the CX 998c and also the older 998 NETFLIX works very good now kodi works very good ever thing works .
Just use the normal rockchip flash tool and select img and flash the thing and al is good its a ugoos u3 ported to the CX998.
Originally posted by dproductionz View PostCan anyone post the original rom for this device?
Many thanks
Does it have unified storage or partitioned? If partitioned, how much app space available?
EDIT: Flashed it and it's 2.5 GB, so this is pretty great for 8GB and 16GB devices. Fiddling with it now.Last edited by budgetgeek; 25 March 2016, 13:08.Currently Inactive on Freaktab.com
There are currently 1897 users online. 1 members and 1896 guests.
