T95 Amlogic S905 4K Quad Core 1G/8G 2.4G/5G Dual Band WIFI LAN Bluetooth4.0 3D H.265 OTG
    Another to add to the collection
    Android5.1
    AML8726-s905 quad-core cortex-A9 2.0Ghz
    Mali-450 8-Core GPU
    1GB DDR3
    8GB EMMC
    Communication
    Dual band WIFI 2.4GHz/5.0GHz AP6330
    10/100M
    Bluetooth4.0
    Hardward 3D graphics acceleration
    KODI 16.0
    HDMI 2.0 up to 4k2k Output
    Cheers
    Hello all,
    This is 10 USD discount for this product: FLIYRNFA
    Good day
    Cammy
      Hi all,
      I've got this box (besides an MXIII and an MXIII-G).
      Anyone knows if I could keep the LCD on the front to keep displaying the time when I'm in standby mode?
      Thanks!
        false specs, does not have bluetooth, does not have dual band wifi!
          Just purchased this box and must say it does have potential if it gets maintained properly i.e firmware updates...i have noticed there were afew issues with connection both wired and wireless but after afew factory resets i think its helped...the picture is a lot crisper and sharper than my previous box.. (t8 v2)..but as i say an new update would be welcomed or even a good dev to fire a custom rom at it and i think it would be a worth while investment especially for the price..👍
            I found a 2GB/8GB RAM/ROM version of T95 on page
            http://www.aliexpress.com/item/Genui...580159722.html
            Anyone can confirm this is really 2GB RAM, dual-band WiFi and Bluetooth 4.0 device ?
            Seller is not answering questions (it could be because of Chinese New Year?)
              I just received mine the other day, but not from the same link, and it does have 2gb RAM as well as bluetooth. I ordered mine from **** but the seller didn't say anything about dual-band wifi so I haven't checked. It did say Cortex-A9 on the page but the device and box I received show Cortex-A53. Also, the pictures show android with a navigation bar at the bottom but there isn't. The status bar and nav bar are both hidden. So their screenshots may have been from an earlier firmware. It can be rooted using the ezroot.zip method, with the box's stock recovery not the recovery.img that comes with ezroot.zip.
                Is there any way to get the power button on the remote to just put the device to sleep rather than shutting it off completely? It takes a while for it to turn back on.
                MXQ / M8S+ / MXIII-Plus / Mini MX / Mini MXIII / T95 / Mini M8S II / R68 / V88 / GT1
                  Anyone know if libreelec works on this?
