Things to add, fix or improve
Ideas for new ROM
Originally posted by Roland Deschan View PostUsable for maximum number of RK3368 TV boxes encouraging each to share development.
Baked unified ROM for larger space for Apps etc.
Support for bluetooth mic etc.
Consistent button/mouse movement across Apps with normal remote.
Can you share more about the bluetooth mic problem? Is there no sound?
Have you tried and see if Soundabout can get audio through bluetooth mic?
Nagrace Home Launcher is very IR Remote friendly with big icons, file manager, install/remove apps app etc.
and eg. double press home button to open Kod(with https://play.google.com/store/apps/d....home2shortcut app), 1 click home button to go back to launcher, hold menu button to hide/show status bar.
The best is still to use an airmouse.
Also Nagrace HPH NT-V8 has LeHome Airmouse/remote control/touchpad/game controller app for smartphones & tablets, so that works very well if you don't want to use the IR Remote.
Originally posted by gregger2k View PostNetflix in HD ;-)
Netflix only allows American companies to have HD Netflix or a select few devices running Linux.
Different countries should come up with their own services similar to Netflix that work in HD on all different devices, maybe then Netflix will start to think about supporting more devices and enabling HD.
A good alternative to Netflix is Showbox(lots of HD) but might not be usable in every country.
Originally posted by Will2 View Post- Rom that supports Google TV apps and Google Launcher.
- Zidoo port for Z4
- Skype Mic Fix
- Portable USB Dvd\Blu Ray Support
Now I'm trying to make stable Lollipop firmware.
Skype mic fix - not sure if it's a problem anymore. Doesn't sound get routed correctly from the mic?
USB ISO and other file systems are supported.
It will also run Linux, so then most file systems and USB devices will be supported.
Because Zidoo or Z4(Eny) doesn't release source code of their boxes it's very difficult to port ROM's from one device to another and also difficult if you don't have any of these devices to test with.
Originally posted by mo123 View PostGoogle TV apps might be usable in Marshmallow firmware to be released later.
I plugged in a usb dvd player and put in a dvd no dice. Wonder what happened to the support.
I'm able to run Google TV apps and Launcher with a build prop change. Wonder how easy it is to modify the APK so its not needed.
I've believe someone has modded a ziddo X6 firmware on the 4pda forum, but haven't had a chance to try it.
What build.prop change did you make?
I'll find out about the DVD support.
I believe the DVD support problem is an ENY Tech issue. I'm not currently on your firmware. I should receive a new Z4 tomorrow and will try a few roms out.
This is what I changed and side loaded Android TV launcher. Some apps work some don't.
ro.product.model=ADT-1
ro.product.brand=google
ro.product.name=molly
ro.product.device=molly
https://www.exploitee.rs/index.php/A...ple_Build.prop
There are currently 2143 users online. 3 members and 2140 guests.
