Just delivered MK808B Plus, what do I need to know?
    Hey there
    I jost received my MK808B Plus from GearBest.
    Now I need to know, what I have to know before flashing some custom roms for it.
    First of all, it is running 112K4.
    Any newer stock rom out there?
    Checking Geekbuying I find a "updated firmware" dated 15.12.2015 (Day.Month.Year ) Is it really a stock rom and if yes, what versions number does it have?
    http://blog.geekbuying.com/index.php...date-20151215/
    In the attachment you find my devices info. Is it possible to read what version of mk808b I have? Or do I still need to open it?
    //Well finally I found out, the different clones were about the MK808B with a RockChip ... Uploading my pictures anyway.
    https://dl.dropboxusercontent.com/u/...2020.54.45.jpg
    https://dl.dropboxusercontent.com/u/...2020.55.37.jpg
    What tools/drivers do I need for updating the firmware?
    I have read about some kind of FAQ, but I did not find it yet, is there one?
    Thats all for the first.
    I hope you can help me and I don't ask question for the repeated time. :/
    It is my first android based tv stick.
    Only got the fire tv stick too, but that is another world...
    Mfg
    Stimmenhotel
    PS: oh yes, any recommendations which rom to use? I would have gone for the finless one suiting my device. But maybe another one?
    Edit: Alright, already started it up.
    Using a Mele F10 Deluxe, the first thing I discover is, the home key is not using the android home button, instead something like home key on a windows keyboard.
    Another thing ... I was trying to use hardware acceleration for video playback i kodi.
    Using the logging feature it tells me it is using the cpu ...
    Am I doing some thing wrong? HW acceleration is activated inside the settings.
    Youtube only shows me 720p, even if I set the display to 1080p 60Hz...
    Limitation of youtube or my fault?
