Anyone running modern combat 4?
Originally posted by livinlife View PostMk808 with finless 1.7c
Maybe ask Bob to spoof another device for this rom so it will work.
Did you buy and install a legit version or did you try to install a cough cough free version??
That could make a world of difference.
Originally posted by livinlife View PostI bought it from the playstore. $6.99 isn't breaking the bank :-)
Just another quick couple of questions for ya though.
when you download from the play store does it download and instill then says something like cant be played due to device or will it not even download or does it just download and you cant even install the game??
If it downloads ok but wont install you could do the download but dont allow the install.
After it finishes downloading go into device settings/apps/modern combat 4/cache/ and delete all past data files and then try to install the game via apk manager.
If this fails we know for a fact we need a new spoofing device added.
Could also mean it doesnt like JB 4.1.1 1.7c rom and may need to be updated to JB 4.2.2......
Re: Anyone running modern combat 4?
Mc4 works fine for me using imito mx1 jb 4.1.1. I bought it one my phone and then took the obb files from android/data/obb from my sdcard and put on my android stick. I then installed the apk and all works. Except cannot get wired xbox controller to work for touch events like usual.
Sent from my SGH-I897 using Tapatalk 2
Originally posted by ricont View PostHi,
I havent tried MC4 but the MC4 (Zero Hour version) is working on my MK808B 1.7
ricont
You dont have enough space on your device.
It may show you have enough space but you dont.
its trying to download but wont means its downloading to the partition with the least space and freezing casue it doesnt know how to act with unavailable app space so it will just show that its downloading for ever and ever.
I know first hand because this crap happened to me with need for speed most wanted.
It shows I have plenty of space for apps like 5 gigs but when I tried to download it just stayed downloading for like 4 hours 3 times in a row,
I then reflashed with my device with 2gb app partition option and now for what ever reason instead of 2gbs for apps, my apps get installed to 6gb nand partition with the Os for every big game and for smaller games like plants vs zombies or candy crush saga install to 2gb partition automaticly.
Not my choice... But after I was able to download and install any game without issue..
Originally posted by thunder22 View PostMc4 works fine for me using imito mx1 jb 4.1.1. I bought it one my phone and then took the obb files from android/data/obb from my sdcard and put on my android stick. I then installed the apk and all works. Except cannot get wired xbox controller to work for touch events like usual.
MC4 zero hour version is running fine with my six axis controller/app
ricont
Originally posted by Justinbaileyman View PostYep, OK I know what your problem is now for sure.
How are you guy's playing the game with your controller? I use a usb controller that looks like an xbox controller but is meant for a ps3. On the game I can move with the left stick, but I can't aim. I downloaded the sixaxis app in hopes that it might work with a usb controller, but it appears that it needs to pair to a bluetooth controller. Since I have a MK808, that won't be an option. I refunded it and then tried the usb/bt joystick center. It was a no go as well. I had heard this game had limited gamepad support. I guess when they said limited they meant limited.
Originally posted by livinlife View PostHow are you guy's playing the game with your controller? I use a usb controller that looks like an xbox controller but is meant for a ps3. On the game I can move with the left stick, but I can't aim. I downloaded the sixaxis app in hopes that it might work with a usb controller, but it appears that it needs to pair to a bluetooth controller. Since I have a MK808, that won't be an option. I refunded it and then tried the usb/bt joystick center. It was a no go as well. I had heard this game had limited gamepad support. I guess when they said limited they meant limited.
For Sixaxis controller/app you can use the touch emulation and create your own touch profile,
you can also use the touch profiles from XDA developers forum.
The playing experience is almost just like a normal game console.
ricont
There are currently 2357 users online. 2 members and 2355 guests.
