My usual mods, etc...
No I did not change the mouse pointer. I can do that later if everyone wants it.
Enjoy,
___________________
Features and release notes for my MK908 4.2.2 1.4 ROM:
1) Rooted and new SU and Superuser applied that supports Android 4.2.2
2) Stock ROM was only 2 Gig of APP space.
BUT you also have parameter file options!
There are also 1gb, 2gb, 4gb and 6gb options.
Read below for how to change that in the flash tool.
Realize if you use this 6gb option, internal SDcard will only have about 600 megs of free space!
3) Debloated of junk APPs and Google Apps you can get from Google Play.
I also updated Google Play to the latest version along with standard APPs.
4) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
5) I re-enabled location services. This is now in the settings menu.
Tested and working with all APPs that use it.
Remember to turn off GPS as we have no GPS.
6) I also re-enabled accessibility options in settings.
7) Gameloft fix. This fixes Gameloft games from crashing to the desktop.
Many of them do not run and crash to the desktop. This is due to a license check based on the device.
Special thanks to Christian Troy for inventing this fix. I modded it for this ROM.
8) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
I am spoofing a Samsung device that will show almost any APP as compatible.
Your device will show up in google play as Samsung device not a MK908 or RKSDK! Understand this please.
I also left the original build.prop in the ROM called build.orig.
If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
Then rename build.orig to build.prop.
Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
Reboot! You should be back to showing up as a MK908
9) RK Mirroring is enabled as always.
Also new to Android 4.2.2 is Wifi display.
If you have another 4.2.2 phone or tablet you can share your devices screen on your TV.
10) Remote Control using RK Remote APP is now fully supported!
In the ROM kit is a RKRemoteControl.apk.
NOTE: This is a NEW version and will not cause your TV stick to crash.
So if you have already installed RKRemote before you need to un-install it and re-install this version!!!!
You install this on your phone or tablet and now it can remotely control your TV player!
Just put the APK on sdcard or something and install it on your Android phone, tablet, etc.
ENJOY this one! I had a HARD TIME getting it to work!
11) I added a reboot APP that will allow optional reboot options like reboot to bootloader (flash mode).
For more information ALWAYS read the README in the ROM kit!
_______________________
Here are the links for Android 4.2.2 Finless 1.4 ROM
ROM -> Tronsmart MK908 Android 4.2.2 BETA - Finless 1.4 ROM (245 megs)
Enjoy,
