MEASY RC11 and RC12 all working keyboard now
    Test working on Finless mk808b original 1.7
    Test working on Finless mk808b original 2.1
    Should work for any Rom from any Finless sauce and other.....
    Have manage to remap missing button on my rc12. To do the work without messing up with the generic.kl what you never have to do to avoid some problem. i built my own Vendor_0c45_Product_7403.kl file instead. built a .kl file for a specific vendor id/pid keyboard take advantage to remap key withoout touching the generic.kl who could be needed when other device could use this generic.kl file.
    it is recognize instantly when those measy keyboard are connect to usb.
    most of f1 to f12 was useless before.
    non-working button who now works great:
    F2 (internet explorer icon) = Browser
    F3 = search
    F4 = home (return to home whenever a app is open)
    F5 (envelope icon) = mail (open email really fast )
    F6 (music icon) = rk music player
    most important to me to work are below and test to work with all media player of your choice:
    F7 MEDIA_PREVIOUS or skip back not the rewind. to rewind dpad left
    F8 MEDIA_PLAY_PAUSE
    F9 MEDIA_NEXT = skip to next file. To fastforward dpad right
    F10 MUTE now it work
    F11 vol- now it work
    F12 vol+ now it work
    but also work with rc11 cuz it is same #key and same usb pid/vid
    All good now but...
    using now f11 for it real purpose (vol-) this way i lose the f11 function i have before to hide or restore the finless status bar (system bar) who is pretty incompatible while playing a youtube video from the youtube app .
    just this old f11 function (show and hide bar) to remap to f1 but what the name of this function ?
    The only thing before to share this file with forum user is to know how to pop up this bar from f1
    any help?
    temporary file before i fix the systembar problem and update the thread: (all other key work great)
    put this Vendor_0c45_Product_7403.kl file to: /system/usr/keylayout/
    Reboot the droid
    Measy rc11 and rc12 keylayout.zip
    Regards
    Last edited by malfrat; 29 May 2013, 10:42. Reason: Should work for any Rom from any Finless sauce.....
    humm someone could send me the original Generic.kl from any finless rom ? don't want to reflash my mk just for this...
    NEVER touch this...
    i baddly do what i doesn't recommand but for a just cause
      Speaking of the RC11, how do you find it generally as I have been looking at getting one?
        i've got an rc12 only who is great but with fresh battery....
          Thanks.
          I may just invest.
            Great work!
            I am adding a link to this thread in the FAQ thread.
              Could anybody please help to find out which function is mapped to the f11 key before so that he can remap the f1 key to "hide statusbar"?
              Otherwise the good work isn't very useful for me
                Thanks for this - will give it a go
                For some reason my MEASY F11 right mouse button doesn't work - is that normal?
                This should be great - thanks v much.
                  OK - not great
                  Find it ok - not great - have to point at the screen all the time and can drift when pressing left mouse button so you have to 'keep up' with the drift. The RC12 with its touchpad must overcome this sort of thing so be easier to use.
                  The function keys only part work - hopefully this file will sort this. The keyboard repeat is set so that you cannot type a sentence without eeeeeeeee or xxxxxx etc.. appearing, and the rubber keys frequently stick down. That means your nervous when entering data into a form etc... for the inevitable repeat key mess and correction hassle.
                  The build quality is not great in that sense. However, it kind of does the job.
                    Just map key 59 as F11. This will make F1 function just as F11 did before.
                      doesn't work i've tried before. if you get more lucky thn me with this please upload this working modded keylayout file .kl
                      Thx
                        Thx
                        It's exactly what I did on mine and worked perfectly. I'm at work now and will upload it when I get home.
                          It would be very nice if you could upload it!
                          Thanks a lot
                            I just switched F1 with F11 in Generic.kl now.
                            Does anyone know how to map CTRL + ALT + DEL? I want it on the power key of my RC12 to turn it on via remote, only turning screen off is not very cool.
                            regards
                              Here's the keylayout file for RC11 and RC12 that malfrat made and I just changed the F1 key to F11.
