Ugoos UT4 Rockchip RK3368 2GB/16GB HDMI 2 4k/60Hz 100/1000 Lan/AC Wifi
    Found over a CNXSoft Ugoos UT4
    TearDown
    I think it's the only RK3368 device with a fan inside.
    UGOOS always make high quality products.
      Generous case venting too and not just on the bottom.
        It is a nice build and great firmware IMO.
          is this firmware Geekbox TV suported ?
            Geekbox uses different wifi and led light, so only Geekbox firmware will be fully compatible with their own devices.
              ok.thnks. Do you organize a custom firmware.
                Also available in white:
                Android 5.1: Rapid and stable system,
                4K x 2K UHD video playback, HDMI 2.0 connector:
                Dual band WiFi:
                2GB RAM + 16GB ROM:
                Infrared remote control:
                  It looks good in white. I could just see this setting on my beautiful white grand piano.....if I had a beautiful white grand piano.
                  Seriously though, I like the white one.
                    is that an IR remote?
                      Yes it is. More details are available here.
                        Ugoos UT4 video demo ???
                          Originally posted by mulderfox
                          Root for the UT4 anyone? I saw that the UT4 firmware can be used for other RK3368 devices, and there's even one floating around rooted. Does anyone have a good rooting solution?
                          tried all I could fine and nothing worked.....even had a so called paid service for rooting tell me that it couldn't be rooted as of yet.....
                            geekbuy coupon code ??
                              And the Black one
