LAN port not being recognised
My X7 has suddenly stopped recognising the LAN port on start-up. If I reboot everything is okay but on cold start no LAN, no Internet. The adapter only sees Bluetooth and the wi-fi, which is disabled, and the useless Windows 'problem-solver' just wants to turn the wi-fi back on. This has suddenly started happening for no apparent reason I can find. Nothing has been changed. For months it has started up without problem, now I have to boot twice before it sees the LAN port. Does anyone know anything about this?
Tags: None
Same here. I was wondering if it's something to do with Windows 10 and the LAN drivers being old and buggy. When the unit restarts 50% of the time the LAN port isn't working even though the lights are flashing. It's not to do with the screen sleep mode for me as the USB and LAN ports are enabled whereas when the screen sleeps they get disabled.
The event log mentions 'A request has been submitted to promote the computer to backup when it is already a master browser' and an issue with \Device\LanmanDatagramReceiver
https://msdn.microsoft.com/en-us/lib...or=-2147217396
so I followed the below recommendation disabling 'Computer Browser' in services and seeing how things go.
http://www.hightechdad.com/2007/05/0...d-8003-errors/
http://www.yellowpigs.net/mirrors/CM...c/node140.html
Originally posted by FredQ View Post
I have done a few days testing this now after doing what you suggested and it actually seems to be working! Thanks for your help
Anyway I've had 6 days of 24/7 uptime and no LAN disconnections as well since disabling 'Computer Browser' in services. Whereas before the disconnections were daily.
Originally posted by ultrabit View Post
Are you using Windows 10 with the December update also? I'm thinking the update may have altered something.
That's right, got the latest update on my box. Still going strong.
I spoke too soon! I had one disconnection yesterday for a different reason to detailed above recorded in the system log. I've disabled 'energy efficient ethernet' in the ethernet adapter config settings which has turned itself back on since upgrading to windows 10. Disabling it before seemed to help matters with windows 8.
There are currently 3151 users online. 0 members and 3151 guests.
