If I plug the charger, the charging led is yellow and never turns to green. I have a charging problem? Can I do something about it? Maybe charge the battery directly, as explained here: http://www.slatedroid.com/topic/22913-tablets-battery-not-charging-solution-found/
Arnova 9G2 almost dead, maybe charging problem
I want to use my old Arnova 9G2 for some simple stuff. I had one of finless roms installed and it was OK, but suddenly the tablet doesn't turn on using the power switch. It turns on when I plug the usb cable (tablet to PC or to usb charger), and then it gets stuck in boot loop (ARNOVA logo, then Finless logo for a few seconds and then restart). I flashed finless rom again, I flashed other rom too, and the problem remains.
Tags: None
There are currently 3031 users online. 1 members and 3030 guests.
