ROM that works with Lapdock?
    I have a R28 and cannot find a rom that will output 1366x768, the native resolution of my Atrix Lapdock (stock 4.4 and Wasser Lollipop 3.0.2 output the same low res). I am ready to recompile a kernel and flash it. Could any one point me to a solution (I have not been able to find any here).
    Thanks in advance !
    Hello,
    I think you need to make a Custom Rom.
    You can use the Firefly Sources.
    Also, if you want i can take a look for you and make a Kernel.
    Neomode
      Many thanks! I have written to Wasser to ask him the source code of his kernel.
      If http://freaktab.com/forum/tv-player-...solution/page2 does not work, I will indeed need you help !
        Ok, I will look into it later that Day for you.
        Neomode
          I have PMed Wasser about this issue, but have received no answer. Would your ROM work on an r28 (I have not seen any indication that it would) ?
            Hi, still no news about this. Question: would it be possible to use your rom for another rk3288 device ?
