Sequence of events
TWRP 2.8.6.0 Ported by <mr.d.macdonald> ...loaded days back.
Downloaded, and installed V 1.08 for T9 from here.
Installed file from within TWRP, then opted for root option.
Locked up. Must have been the version of TWRP !
ADB Sideload will not start.
Have restore files loaded on the SD card. They show in the TWRP file manager, but when I try to select External SD Card in the Restore function ...the files are not there (nor any other files, System or otherwise).
