this is my first post here, I hope this forum can help me with my issue.
The issue I'm trying to address is that I want to be able to play videos on my tv, The videos are located on my computer. It's a fairly simple task, so I hope the answer is also fairly simple.
As I understand it, this forum is mainly for android TVs, but my question is actually broader: I'd like to know what is the easiest tool that I could use to reach this objective, whether buying an android TV or not, and if so, then which one should I buy.
Here are some additional constraints / remarks:
- Video quality: up to HD
- Video encoding: I want to be able to play virtually all encodings (such as the ones supported by vlc)
- The TV is not in the same room as the computer
- The TV has various unused HDMI ports
- The TV does not have the ability to read data present on the network (no wifi/ethernet)
- I don't want to set up a long cable between the two rooms (such as a long HDMI cable)
- I don't want to have to go to the PC to manage the videos (such as choosing which video to play, or use pause, next, forward, ...), which is what chromecast requires, from what I gathered
- I do not need any other feature provided by the android TV except for this one, so if there's a better or cheaper option, I'd gladly take it instead
With all that in mind, is the best option an android TV + a NAS server ?
Thanks.
