Best Firmware/Rom for Mk808b plus clones
    Hi ,
    Please can you suggest the best firmware/rom to use on my Mk808b plus (BoSuntop brand) purchased from aliexpress?
    I heard different wifi chips are being used for this model so flashing any firmware without knowing the wifi chip can cause wifi & bluetooth problems.
    Is there a rom which would work fine with all the models ?
    Originally posted by techlover7 View Post
    Hi ,
    Open the pen and read the wifi module name from the chip..then you will know which rom you can install
