I've been bought a OTT TV BOX 4x Android TV player, and a friend updated it today, and showed me how it works on his TV. Unfortunately, when I connect it to my TV via HDMI, it disables all use of my TV. I've tested it on another TV and it works fine, but just not on the TV I actually want to use it on. The TV is an LG LCD TV if that makes any difference. Has anybody else had this problem?
OTT TV BOX 4x Android TV player disables use of host TV
Hi all,
I've been bought a OTT TV BOX 4x Android TV player, and a friend updated it today, and showed me how it works on his TV. Unfortunately, when I connect it to my TV via HDMI, it disables all use of my TV. I've tested it on another TV and it works fine, but just not on the TV I actually want to use it on. The TV is an LG LCD TV if that makes any difference. Has anybody else had this problem?Tags: None
If you know how to edit your build.prop you can try adding these lines to your build.prop
You Will need root access (Typically on most of these units i have noticed installing supersu from google play is all thats needed, but I may be wrong about your unit)
ro.platform.has.cvbsmode=false
ro.platform.hdmionly=true
ro.platform.has.cecmode=false
But make sure you only want to use hdmi
Hi Nick314, thanks for your reply. By 'disable' I mean that I cannot use the remote control for the TV at all, this not being able to switch the input source to HDMI from DTV. Neither do the buttons on the side of the TV work, so I can't even cheat it that way.
The TV doesn't switch off, I just can't use it at all. It's just that TV, and not the other ones in the house that doesn't like the connection to the box.Last edited by Carder123; 05 January 2016, 19:32.
There are currently 3063 users online. 0 members and 3063 guests.
