TWRP 2.8.7.0 for Cube T9
    1. This is not ported TWRP, and it is compiled by jemmini from 4PDA specially for Cube T9.
    2. The most important plus, unlike previous versions, the correct mount partitions.
    3. All other features of previous TWRP present.
    4. To recover backups that were created in previous versions of TWRP, don't forget to rename the folder where they are stored in "Cube_T9"
    TWRP
    Посмотреть и скачать с Яндекс.Диска
    Compiled? Kernel source code available for T9?32 bit version or 64bit? Great work anyway!!!! Thanx
      yes, compiled based on stock firmware 1.07
        TWRP
        Can you post the link about the discussion in that forum?
          This version work very well and solve the bugs of sevenmaxs version
            Works for me too. Would've preferred a better starting screen thou.
              helgiman do you have kernel source code...or is it enough generic source code for MT 6752-8752? just curious!!!
