OLD - Tronsmart T428 Android 4.2.2 - Finless ROM 1.5 BETA
    OK folks.... as many have been seeing posted here, Tronsmart came out with a much better ROM for the MK908 yet they have not seemed to touch the T428
    Not sure why....
    Well it was an EASY PORT to the T428! So now I have a new ROM for you folks!
    This is WAY better than the stock 4.2.2 T428 ROM or my 1.4 ROM.
    It has fixed many things.
    Note: Bluetooth WILL NOT WORK on this ROM.
    That is, BT will pair with a device but the device wont actually work.
    I spend a freaking day trying to figure out why. Bottom line is Bluetooth is so intertwined with the kernel and system, it just is not going to port. But I have not given up as it makes no sense to me why! I am missing something in the port I am sure of that. But trust, if I can fix it, I will!
    Anyway if BT is totally not important to you, then this ROM is a major improvement over the existing 4.2.2 ROMs for the T428.
    Also, I am calling this a BETA because I just whipped it out and ported it! The T428 is in desperate need of a new ROM. I figured you guys deserve it. So this is a BETA because I could not spend all day testing the normal stuff I test!
    I am calling this a Finless 1.5 ROM to make sure there is no confusion with previous ROMs
    Enjoy,
    ___________________
    Features and release notes for my T428 4.2.2 - 1.5 ROM:
    Features and release notes for my 1.5 ROM:
    1) Rooted and new SU and Superuser applied that supports Android 4.2.2
    2) Stock ROM was only 2 Gig of APP space.
    BUT you also have parameter file options!
    There are also 1gb, 2gb, 4gb and 6gb options.
    Read below for how to change that in the flash tool.
    Realize if you use this 6gb option, internal SDcard will only have about 600 megs of free space!
    3) Debloated of junk APPs and Google Apps you can get from Google Play.
    I also updated Google Play to the latest version along with standard APPs.
    4) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
    5) I re-enabled location services. This is now in the settings menu.
    Tested and working with all APPs that use it.
    Remember to turn off GPS as we have no GPS.
    6) I also re-enabled accessibility options in settings.
    7) Gameloft fix. This fixes Gameloft games from crashing to the desktop.
    Many of them do not run and crash to the desktop. This is due to a license check based on the device.
    Special thanks to Christian Troy for inventing this fix. I modded it for this ROM.
    8) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
    I am spoofing a Samsung device that will show almost any APP as compatible.
    Yuor device will show up in google play as Samsung device nopt a MK908 or RKSDK! Understand this please.
    I also left the original build.prop in the ROM called build.orig.
    If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old
    Then rename build.orig to build.prop.
    Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
    Reboot! You should be back to showing up as a MK908.
    9) RK Mirroring is enabled as always.
    Also new to Android 4.2.2 is Wifi display.
    If you have another 4.2.2 phone or tablet you can share your devices screen on your TV.
    10) Remote Control using RK Remote APP is now fully supported!
    In the ROM kit is a RKRemoteControl.apk.
    NOTE: This is a NEW version and will not cause your TV stick to crash.
    So if you have already installed RKRemote before you need to un-install it and re-install this version!!!!
    You install this on your phone or tablet and now it can remotely control your TV player!
    Just put the APK on sdcard or something and install it on your Android phone, tablet, etc.
    ENJOY this one! I had a HARD TIME getting it to work!
    11) I added a reboot APP that will allow optional reboot options like reboot to bootloader (flash mode).
    12) I have adjusted the mouse pointer size by request!
    Stock rom was 55x55. The normal mouse pointer is 22x28 which is too small for many.
    I made a 35x35 mouse pointer.
    If you want to change that more discuss online and I will tell you how to do it.
    For more information ALWAYS read the README in the ROM kit!
    _______________________
    Here are the links for Android 4.2.2 Finless 1.5 ROM
    ROM -> Tronsmart T428 Android 4.2.2 - Finless 1.5 BETA ROM (245 megs)
    Enjoy,
    Bad Link
    HTTP 404 Not Found?
      Hang tight please.... There was a problem with the upload.
      I am correcting it now. I will post back here in about 20 minutes once it is fixed.
        OK Download is ready!
        Sorry for the problems folks... the download link in the first post is now good to go!
          You are the man! does this include cifs support built in? I am going to play with it right now lol will post my initial results soon
            1080p kernel. Nice!
            I just saw the 1080 kernel part. Ahh yeah! Im going to flash it right now.
              Ok, so did some testing. Rom is very snappy for the most part, I tested a 720 hd mkv of bullet to the head in both archos video player and mx player and in both there was a noticible lag during playback at least in comparison to the stock 4.2.2 rom. I also tried mounting my nas in cifs manager and that didnt appear to be working either. But usb storage is working and wifi is working
                Hey Bob,
                I'm might be missing something but I'm not seeing the 1080 kernel.img or 1080 boot.img image in the FinlessROM folder for the T428 1.5 ROM. Sorry if I'm on crack and I missed something obvious. Can I use those files form the MK908 ROM?
                Thanks,
                Rivers
                  no 720/1080 boot and kernel
                  Hi. In the FinlessROM dir, there are no files named 720/1080 boot and kernel. I guess file is missing. Could you check this? Many thanks.
                    No 720p/1080p file..............
                    Hi. In the FinlessROM dir, there are no files named 720/1080 boot and kernel and no rkcontrol apk. I guess file is missing. Could you check this? Many thanks.
                      Sorry there is no 1080 kernel for the T428. I had used the same readme as the MK908 and forgot to remove that feature. They only made a 1080 kernel for the MK908.
                        Oh bummer.
                        Oh bummer. I was wondering if it was a read me typo. Well I'm using the mk908 now with the 1080 kernel and it looks awesome. I think the task bar looks good a little smaller like that but I do miss the big icons. I'm installing/configuring go launcher and next launcher so I can resize the icons that way. Its getting a score of 91 in linpack where it was getting around 120 before so I'm really happy with that too. Just for comparison the MiniX X5 went for around 75 on 720p to 40-45 on the 1080p so this its still a great score. I like the new mouse pointer too. Well thanks for the ROM!
                        Rivers
                          Do you think it would be possible to use the Xposed Framework Mod to quickly fix the Bluetooth in this ROM? Maybe put an BT apk/mod together based on the original 4.2.2 ROM and install it through Xposed to get it working for now?
                          That may not be even possible, but just a thought.
                          TV Stick: MK808 // Tronsmart T428
                          ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
                          CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
                          Recovery: ClockworkMod
                          Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
                          Phone: Samsung Galaxy Note II
                          ROM: Whompasaurus v4.2
                          Kernel: Persus
                            If your using the 1080 kernel and want the larger icons back then since you are rooted go into /system and edit build.prop
                            Change this line:
                            ro.sf.lcd_density=160
                            to this
                            ro.sf.lcd_density=240
                            Reboot and BAM... your larger icons are back!
                            FYI, this really should have been posted in the MK908 thread as the T428 does not have a 1080 kernel yet!
                            But I am going to compare the 2 MK908 kernels and see the differences and if small, binary patch the T428 kernel.
                            Wish me luck!
                              When I erased NAND it counts up to 2042 and no more. I had Finless 1.4a before. I tried it many times according to the "readme" instruction but no success.
                              I really need some help what to do now!
                              Thank in advance.
                              Now my device (T428) does not boot.
