How do you remove the antenna?
    I was wondering if anyone has figured out how to remove the antenna from the Z4 unit. My unit is hardwired to the switch and I would like to remove it, as it is in the way.
    Thanks,
    GD
    You can pull the sides at the bottom of the antenna to detach the clips
