Remote and Wifi/Ethernet doesn't work with MXQ Megatron V1 or V2...
Hi, Thank you for making available this ROM, it’s really nice.
I already use it on my M8 flawlessly, but I’m having trouble setting it up on my MXQ, the remote and Wifi/Ethernet doesn’t work, already tried V1 and V2…
The ROM that makes remote and ethernet/wifi work correctly is here:
Is there anything I can do to make remote/network work with megatron?
Cassio
Maybe... I prefer to make roms that will benefit masses rather than one offs. Can you send a screenshot of the current ROM build information? If you have the PCB reference that would help too.
Please find the pictures attached.
I believe a lot of people will buy this device, since it's the cheapest MXQ available on aliexpress...
Thank you man.
Cassio
You may only view thumbnails in this gallery.
This gallery has 7 photos.
