chinese (ps3 like) low-cost gamepads now for you + Logitech F710 on DirectInput
    Test on mk808b original Finless 1.7 rom
    Done!
    I remark that most of all this chinese low-cost copy ps3 like gamepad have all the same pid/vid....
    your really out of luck if not. Also included a Logitech F710 on DirectInput one.
    Also included correct mappings for:
    • Vendor_046d_Product_c219.kl: Logitech F710 on DirectInput
    • Vendor_0079_Product_0006.kl: for chinese controllers such as Speedlink Strike gamepad and many other if not all
    The modules:
    • ff-memles.ko
    • hid-dr.ko (for chinese controllers such as Speedlink)
    • hid_logitech.ko (for F710 on DirectInput, XInput is in xpad)
    • xpad.ko
    Install with a 'root browser' of your choice:
    You should copy the *.ko files to e.g. /sytem/lib/modules
    and copy the *.kl to /system/usr/keylayout/
    File:
    Chinese_gamepads_compiled_modules.zip
    Done!
    The modules:
    • ff-memles.ko
    • xpad.ko
    I am using Finless Rom 1.7 for the Imito MX1 with 2 Logitech F710's and they already work.
    Can you please explain what these modules do.
      humm, just doesn't know that 1.7 already got that.
      but this was an extra anyway. My first plan was to integrate those chinese pads.
      Regards
