Does anyone with a U1 know either of the following:
What is the display density (I like mine at 160 as it is on a small monitor in the kitchen) and can it be changed easily (build.prop etc) or is is like the older AMLogic ROMs where its hidden away somewhere? (I know the cmd am display-density can be used to change after boot but some core UI elements need a restart of the service to take effect which is a bit messy).
Is multi user enabled? If not has anyone tried adding this to the build.prop to see if it works? I guess you may need a lock screen set like in 4.4?
fw.show_multiuserui=1 fw.max_users=4
