TWRP 2.8.7.1 for Cube T9
    I have noted many TWRP versions. Is this a more stable or improved version for the T9?
    I have TWRP on my T9 now ..2.8.4.0.
    Would this be a better version?
    Looks easy to install the image with the version I have on the tab now.
    Cube T9; Pipo M8 Pro (on life support); LG gPad
      You will find the answer yourself by reading this article.
        its ported TWRP for another partition layout. what its advantages over in 2870 from jemmini?
          Just ported few hour ago, I don't know any more about it,
          According my opinion, The main functions is no significant differently .
            I have TWRP 2.8.4.0 installed, but I have never flashed an image using it, just zips. Would I choose the nvram, uboot, recovery, or reboot option on install?
              I unpacked the version 2.8.7.1 by Iceman:
              This recovery is based on modified 2.8.6.0.
              It presents the same problems of 2.8.6.0 (initial message partition unmodified, given the presence of the /data partition among those eligible as a destination for backup)
              In the default.prop is present same "ro.build.user"
              My conclusion:
              The 2.8.7.0 by Jemmini is for me the best currently available.
                Dumb noob question, I am sure. I downloaded from here.. Ver. 2.8.7.0-m8.
                Same as 2.8.7.0, and ok for the T9?
                  This is a completely different platform qualcomm processor...impossible to work!
                    Appreciate that.
                    So then does anyone have a link to the 2.8.7.0 for the T9?
                    I searched and was unable to find.
                      bad looking
                        Bad looking.... as in 'good' or 'bad'?? Is there a problem with the image?
                        It downloaded as' rcoveryjeng.img. I assume this is the proper file. ??
                          I mean you're bad looked for
                          yes, proper
                          this is twrp 2.8.7.0 compiled by jemmini from 4pda specially for Cube T9
                            yes, proper
                            Loaded the image, made a new backup. Looks good.
                            Now to understand all I can do with this latest TWRP!
                              I am a bit confused and need a bit of help.
                              The new TWRP has a feature to increase partition size, but everything I seem to read speaks to increasing the system portion by finding un-used space. Also it is usually in reference with Nexus, not the Cube T9.
                              So can I increase the internal storage on my T9, and is it done by making the usb storage portion smaller? Or am I looking at something entirely different?
                              I have changed partitions on my pc many times, but this concept looks different.
                              Thanks for any and all help. 😊
