Now after its first run i am having too much issues
1. Tv box hangs every time when ever try to update any app from google play store or even manually from apk
2. kodi not working properly , also hangs the tv box sometimes
3. on installing a new app from google play store or any other store or apk hangs the tv box
Tried to install many img's and custom roms from all over the internet including 4pda and freaktab
but the problem is same with every rom and img
Any suggestions ? or help
Is it on the latest firmware? Check to see if there is a upgrade waiting to be deployed.
how cn i confirm my vendor that this problem is a HW problem ?
Unfortunately you can't as the manufacturer of your device is Eny Technologies and they provide zero after sales support.
There are several threads on Freaktab to warn people against their slapped together boxes with no quality control.
